It is currently Mon Oct 06, 2025 5:23 am
Post new topic Reply to topic  [ 541 posts ]  Go to page Previous  1 ... 21, 22, 23, 24, 25, 26, 27 ... 37  Next
PostPosted: Fri Sep 07, 2012 10:57 am
Hi DeeCee,
i'am glad if you could do me some so that i can get a better seight of things 8)
PostPosted: Sun Sep 09, 2012 2:22 am
If you need me to take better photos with better lighting, let me know as I will have to re-install the inlet manifold and hoses etc for the photos. That would have to be next weekend.
GT Four Adovansu
PostPosted: Sun Sep 09, 2012 10:18 am
Wow, you could eat your dinner off that engine its so CLEAN :lol:
PostPosted: Sun Sep 09, 2012 12:02 pm
nah - its dirty and dusty. I'll clean it more after the engine is running.
GT Four Adovansu
PostPosted: Sun Sep 09, 2012 2:23 pm
thanks a lot, that realy helps me
i'am just wondering about one line from the P/S pump, one of the two connects to the inlet manifold and the other one goes to?.....simple to the ISC line???
PostPosted: Mon Sep 10, 2012 8:29 am
Yes to ISC. Don't mind the modification. Integrating st215 manifold and currently arranging alignment.
GT Four Adovansu
PostPosted: Mon Sep 10, 2012 8:43 pm
thanks a lot Mr. DeeCee 8)
PostPosted: Sun Sep 16, 2012 10:13 pm
instead of the engine i did some different work and built a new tower bar
and now after 8month of waiting i should get the turbo next week :)
PostPosted: Sun Sep 23, 2012 9:25 am
the EFR is in house now
[url=http://www.abload.de/image.php?img=efr2sulxp.jpg]Image
PostPosted: Sun Sep 23, 2012 10:03 am
Nice - what model is that?
GT Four Adovansu
PostPosted: Sun Sep 23, 2012 11:18 am
it is the 6758 one, single entry :)
twin entry doesn't becomes available for the B1 frames :(
PostPosted: Sun Sep 23, 2012 1:00 pm
This is a great bit of kit Sunny :D Look forward to hearing how you get on with the installation, setup and performance.
This is a race spec turbo, unlike others on the market. Just thought I'd remind everyone of the specification as currently published by Borg Warner on their web site:
EFR Features & Benefits:
Low Inertia Turbine Wheel
Gamma-Ti Turbine wheel cuts turbine inertia by roughly 50%, dramatically improving turbo response. Turbine sizes range from 55mm to 80mm in Outside Diameter.
Heat Resistant Turbine Housings
Investment cast stainless steel turbine housings improve durability and offer an extremely smooth internal flow channel. Turbine housings have thin walls to reduce weight and thermal inertia.
High Turbine Efficiency
Superback and Fullback back-disk shapes offer very high efficiencies. The Superback shape adds a curved profile to the back-disk and has the effect of lowering centrifugal stress and permitting higher rotational speeds.
Enhanced Turbo Response
EFR Turbochargers use a dual-row ball bearing cartridge with ceramic balls and metal cage. This bearing system provides substantial friction reduction at low turbo speeds and in the process helps improve turbo response. Metal cage improves the durability of the ball bearing assembly.
Flexible Compressor Cover
The EFR turbo "large" cover has a dual-machined outlet, both for a hose connection and a v-band connection.
Simplified Installation
Integrated compressor recirculation valve (CRV) to help avoid compressor surge and backflow during a throttle lift event. This feature helps to simplify the installation task and lowers overall system install cost.
Forged Milled Compressor Wheels (FMW)
EFR turbos contain wheels that are fully milled from forged aluminum, commonly known as "billet". Cut from custom forgings, their strength exceeds that which is available from typical bar-stock and also exceeds the material properties of an aluminum casting.
Sensor mounting convenience
Speed sensor mounting provisions are also supplied on every compressor cover. Speed sensors are sold separately.
Boost Control Solenoid Valve (BCSV)
A boost control solenoid valve (BCSV) is included with every EFR turbo.
High Flow Wastegates
Purpose designed large wastegate ports give the wastegated EFR turbos the capability of handling the flow requirements of high performance applications.
Ease of Orientation
Turbo orientation flexibility is facilitated by the wastegate bracket to bearing housing mounting arrangement.
Adjustable Wastegate
The fabrication and installation task is simplified with wastegated EFR models that feature adjustable wastegates available in three different canister sizes.
PostPosted: Sun Sep 23, 2012 7:03 pm
i hope the installation becomes not so dramatically, first i will mount the IC and then i start to get some measurements for a turbo adapter
but currently i'am not sure what kind of oil and water lines i will use, stainless pipes are my favour, have you'll any tips for me?
PostPosted: Sun Sep 23, 2012 9:28 pm
I havent reached the stage of installing the lines on my turbo but happy to share the solution when we do.
PostPosted: Mon Sep 24, 2012 11:21 am
Hi Don,
sounds great to me 8)
