It is currently Sun Oct 05, 2025 9:51 pm
Post new topic Reply to topic  [ 837 posts ]  Go to page Previous  1 ... 20, 21, 22, 23, 24, 25, 26 ... 56  Next
PostPosted: Fri Apr 22, 2011 4:00 pm
few more bits done today finished the turbo clocking bracket
this is my 1.4bar actuator
all fitted ready to go :)
then I have started to redo the intercooler pipe work
managed to get rid of 3 90degres bends and replace them with 45degre bends
need to get the engine back to gether then i can finish the pipe wokr off :)
PostPosted: Fri Apr 22, 2011 10:29 pm
Great stuff... removing the 90 degree bends will certainly help with flow :)
PostPosted: Fri Apr 22, 2011 10:47 pm
Great to see the progress in pics.The pipe runs look very good :)
PostPosted: Fri Apr 22, 2011 11:21 pm
hoping to have it all rehoned and rings gaped and pistons fitted tomorrow :)
PostPosted: Sat Apr 23, 2011 7:33 pm
ok had a good days work on the car with the help Dug big thanks mate :)
first we set up the ring gaping tool
we did a trial test with an old ring
so onto honing the bores forgot to take photos as we were honing out the bores but as you can see all done and ready to set up ring gaps :)
cheeking the gap on the rings
so we go the top ring for piston 1/2/3/4/5 and placed it in the bores to see what the gaps was
using the piston to push ring down into the bores so we could get the right gap
we had to gap 2 of the rings to get the right tolerance
then build up the pistons
then after doing this to all 4 piston’s refitted them to the block
than is was onto fitting the head and torque everything up
than time to fit cam belt and set timing up :)
not shore what Dug is doing here lol
then re fit exhaust manifold and turbo
I have just dropped the cam cover in place for now to keep it all clean
if the weather is good tomorrow I’ll be out and should have it nearly all back together :D
PostPosted: Sat Apr 23, 2011 9:37 pm
Interesting ring gap tool! I've only ever gapped rings using a flat file on the ring ends. No pics of the bottom end but I guess you just re-assembled the big ends from the bottom using the original shells? Top effort doing all this with the engine in-car :shock: :D
PostPosted: Sat Apr 23, 2011 9:54 pm
yes just re-assembled the big ends from the bottom using the original shells, to be fair its not that hard a job to do in the car :) by using the ring gap tool you can make shore that you take the same amouht of each side of the rings and is very easy to use :)
PostPosted: Sat Apr 23, 2011 10:14 pm
Great effort! Thanks for taking the time and trouble to post pics to help everyone! :)
Bet you were pleased the sun has been out today! It's much nicer doing these jobs when it's warm! :)
PostPosted: Sat Apr 23, 2011 10:54 pm
Was a real nice day with the traditional Bacon sandwich for work done. ;)
Tbh this was.the easiest engine I've put rings in most were.within spec out the box, lucky I guess ;)
At least now it shouldn't smoke and should be a.healthy engine. Original ring gaps were way to big...
PostPosted: Sat Apr 23, 2011 11:07 pm
was a good day :) a few more photos 1 of my other mates took
PostPosted: Sun Apr 24, 2011 7:01 pm
ok done some more work today but been very busy so no many photos
got the sump and everything on and in place
then started on the wiring and fuelling
then refit ally rad
only problem I have had is that 1 of the cables for the plus had broken off :(
it’s the plug that goes to the cold start sensor I think
Image.
as you can see not much room when turbo is clocked
and I am now at this stage
PostPosted: Mon Apr 25, 2011 4:54 pm
a nice day and some morw work on the car done :)
finished the new cold side of the intercooler pipe work :)
hade to make some new pipes up using my little tool :)
so now i have her to this stage
all i have goto do now if sort out the hot side witch is now going to be easy as there isent much room witcha 52mm rad in the weay:(
on a good not i managed to fix the plug
solderd in and fix 2 new wiers to the pulg
then sealed it all up job done
should have new crank pully mid week so hopeing to fire it all up the weekend:D
PostPosted: Thu Apr 28, 2011 8:44 pm
ok got a bit more done to night :) managed to fit the pipe work for the clocked turbo to intercooler
as you can see not a lots of room :(
all piped up now :)
just goto add oil and water tomorrow then it should all fire up :)
PostPosted: Thu Apr 28, 2011 8:50 pm
only thing i rely need now is crank pulley or will the 1 i have with a small chip in it be ok?
will i be ok to use this to start it up nad make shore every thing is runing ok?
PostPosted: Fri Apr 29, 2011 4:20 pm
ok good bad day :( finished al the piping and filled with water and oil :) all good :) then cranked it over for about 5 mins to get oil round the engine, bit I noticed that the oil light wouldn’t go out or the oil pressure gauge did not show any thing :? so need to investigate, there was oil getting the take of plate on the block but not getting up the head :( so there was only 1 thing to do, strip the head off and have a look as I was wondering if I had fitted the head gasket the wrong way round :? so off came the head only took me 2hours I think may be quicker
and as you can see the head gasket was the wrong way round not letting the oil into the head :(
iv called it a day and having a rest now ready to rebuild the egine tomorrow again lol
