It is currently Mon Oct 06, 2025 7:02 am
Post new topic Reply to topic  [ 541 posts ]  Go to page Previous  1 ... 16, 17, 18, 19, 20, 21, 22 ... 37  Next
PostPosted: Sun Sep 25, 2011 12:07 pm
some things are done, i bought a cheap used TRD gauge cluster surrounding becouse a little bit bling bling is allowed
one of my targets for this year was to adjust the rear suspension but after 16year no toe adjusting was possible any more so i deciced to buy a set of pu-bushings, worked out the whohle arm and pressed in ne new ones, for that you have to dismount the longitude arm, the problem was the bolt when i opened him the whole bolt with the buching turns which means i destroyed it so i also had to pu-bush it but i doesn't want to dismount everything so i build a tool for that work
it works perfect and when it becomes to strong just heat it a little bit, but just to press the old one out
PostPosted: Sun Sep 25, 2011 2:38 pm
Great way of replacing that bush! :)
Good to see you are leaving the other bushes on the hub standard :)
PostPosted: Sun Sep 25, 2011 5:06 pm
Hi Kris,
thanks, i doesn't touched them beyouse they are ok but can you explaine why it is better? :)
PostPosted: Sun Sep 25, 2011 7:29 pm
The radius arm bushes are of a spherical design and they have very little "play". Fitting a PU bush will introduce a lot more unwanted movement..
Replacing the inner bush on the rear subframe is however recommended :) (in my opinion)
Rear radius arm bush looks like this...
PostPosted: Sun Sep 25, 2011 8:23 pm
Hi Kris,
i understand, after that i know why i was able to move them so easily 8)
would mean that i have to buy a set of this if i had to replace them anytime
http://www.fensport.co.uk/Parts/Model_1 ... ory_2/2195
PostPosted: Sun Sep 25, 2011 11:07 pm
Yes, that's the part... I strongly suspect that these are sourced from Toyota... part No T42210-14010
PostPosted: Mon Sep 26, 2011 5:53 pm
genuine part.....i though they are not available from toyota? toyodiy say no......
PostPosted: Mon Sep 26, 2011 7:02 pm
They are available from Toyota, I've bought them in the past :P
IIRC they are a part that is listed for the Supra... a friendly Toyota Parts man helped me find it a loooong time ago ~£35 each I think?
PostPosted: Mon Sep 26, 2011 8:09 pm
absolute great, thanks a lot 8)
PostPosted: Sat Oct 15, 2011 4:41 pm
small update
a modified underpanel with the target to raise the air flow trough the radiators and the engine bay
a small plate to protect the gearbox radiator connectors
tomorrow i will mount a fire-extinguisher, and then it is enough for this year
PostPosted: Sat Oct 29, 2011 7:17 pm
today i got the head back from porting
intake:
exhaust:
close up:
not so good visible but all critical areas are deburred
PostPosted: Wed Jan 18, 2012 8:51 pm
small update, the block is stripped and measured some time ago
i ordered CP pistons in 86,25mm 9:1CR
and carillo h-beam rods
PostPosted: Thu Jan 19, 2012 12:24 am
Hi Sunny,
Can I ask where you ordered your rods and pistons from?
PostPosted: Thu Jan 19, 2012 8:52 pm
for sure, i'am glad to answer all questions :)
both are ordered from Fensport
PostPosted: Mon Jan 23, 2012 1:32 am
Thanks Sunny thats great. I didn't know that Fensport sold the 86.25mm CP pistons.
