It is currently Tue Oct 07, 2025 12:04 am
Post new topic Reply to topic  [ 401 posts ]  Go to page Previous  1 ... 16, 17, 18, 19, 20, 21, 22 ... 27  Next
PostPosted: Sat Dec 01, 2012 1:07 am
Was just a brief mail and pics from him but can add your question re alignment to the list when I catch up with him soon.
PostPosted: Mon Dec 03, 2012 11:31 pm
Pedal box, steering etc. installed :D
PostPosted: Tue Dec 04, 2012 6:12 am
Looks great. Comes together fast after all the thinking and fab work is out of the way :)
GT Four Adovansu
PostPosted: Tue Dec 04, 2012 9:16 am
Looks brilliant.
Hopefully it's a bit like an airfix kit now. :)
PostPosted: Tue Dec 04, 2012 2:06 pm
Tell Jon he quickly needs to do the same to mine before he leaves will ya ? :)
Looks beautiful matey.
PostPosted: Tue Dec 04, 2012 4:23 pm
love that so much 8)
PostPosted: Tue Dec 04, 2012 8:30 pm
this looks so cool:)
PostPosted: Tue Dec 04, 2012 11:11 pm
More progress, rear brakes and handbrake cable runs plus installation of the Lifeline Zero 360 extinguisher system. The extinguisher kit comes with all the plumbing and nozzles to cover the fuel tank, engine bay and driver. Designed to buy enough time to get out before the whole thing goes kaboom. Hopefully I will never have to put this to the test :o
PostPosted: Wed Dec 05, 2012 12:18 am
Probably makes more sense to point nozzles at engine, fuel tank and ECU
Save the high $$ items :mrgreen:
PostPosted: Wed Dec 05, 2012 12:30 am
You mean I am easily replaced Steve? :-(
PostPosted: Wed Dec 05, 2012 1:40 am
Well I hear Schumi "will drive for food" :lol:
Replacing the car will cost more than a family bucket of KFC :!:
PostPosted: Wed Dec 05, 2012 6:37 pm
Are you confusing Schumi with Kimi (don's cat!) ?
PostPosted: Wed Dec 05, 2012 7:58 pm
TrackToyFour wrote:
ST185 strut and wishbone mock up. This is to work out how to convert the SuperStrut to a McPherson strut front suspension
I know this was a long time ago, things might have changed and i might be a bit late with this, but i have been doing a bit of research into the mcpherson conversion and i am 99.9999999999% certain that the ST202 wishbone will bolt straight onto the ST205 subframe with little or no modification. and using the ST202 front hubs it should be pretty straight forward.
PostPosted: Wed Dec 05, 2012 10:59 pm
What you say may well be true but if it were me I'd want to test the theory by offering up a non-SuperStrut ST202 front suspension and hub to see if will fit the ST205 suspension pick-up points and drive shafts. In my build I am using ST185 McPherson strut front hubs and custom fabricated tubular lower wishbones because we could guarantee everything would fit and the camber and castor would be OK. For example we found we had to modify the lower 'kingpin' ball joint to obtain enough clearance on full lock.
PostPosted: Wed Dec 05, 2012 11:18 pm
It does fit.....the pick up points are the same, essentially you have the choice of macpherson + 202 rack and subframe or macpherson + 205 rack and subframe....
We went for the former but that was because we reckoned the 202 steering arms had more threads for toe adjustments.
basically it's just the racks that aren't interchangeable so the it's only the rack mounting brackets that make a 202 subframe different from a 205 subframe.
Users browsing this forum: Google Adsense [Bot] and 9 guests
