It is currently Sun Oct 05, 2025 4:04 pm
Post new topic Reply to topic  [ 837 posts ]  Go to page Previous  1 ... 12, 13, 14, 15, 16, 17, 18 ... 56  Next
PostPosted: Sun Aug 29, 2010 12:43 pm
right just bin out for drive and now when croosing at 60-70mph the temps are down to 80-85c :) so im geesing all the little bits i have done now are helping :)
 Post subject: Croosing or Cruising?
PostPosted: Sun Aug 29, 2010 2:07 pm
Hello Louis
Where are you measuring your inlet air temps?
Sorry, I maybe should have read through the other pages!
Stephen
PostPosted: Sun Aug 29, 2010 2:46 pm
Hi mate i have a temp sensor just be for the throttle body :)
 Post subject: Hot to trot?
PostPosted: Sun Aug 29, 2010 2:49 pm
Hello Louis
Would you recommend fitting an IAT sensor in the cold start injector location?
I would also be interested in what kit you are using.
Thanks.
Stephen
PostPosted: Sun Aug 29, 2010 3:10 pm
Interesting feedback from your bonnet intake mod. Have you ever considered fitting a CS/RC bonnet? It's designed to create a low pressure area above the bonnet opening thereby extracting hot aire from behind the radiator and the area around the turbo.
PostPosted: Sun Aug 29, 2010 6:36 pm
i like the look of the ata bonnet so ill just be doing a mod the block the scoop :)
 Post subject: Re: Hot to trot?
PostPosted: Sun Aug 29, 2010 6:38 pm
toyokid wrote:
Hello Louis
Thanks.
Stephen
no you get to much heat soak from there that is whay i fitted mine just in front of the throttle body
i made my own kit if you have a look back throw my build i think it is in there :0
PostPosted: Sun Aug 29, 2010 6:42 pm
new mod fitted nice clear top cam cover :)
and have bin doing a bit of heat lagging to the intercoller pipes
[IMG]
PostPosted: Wed Sep 01, 2010 6:32 pm
new bit for the car :) nice swirl pot
this should help with the cooling
now just need to find room to put it lol
PostPosted: Wed Sep 01, 2010 6:53 pm
That's the tricky part, especially getting the height right!
PostPosted: Wed Sep 01, 2010 7:02 pm
i know how ti fit it but where is the best place as i dont have much room left lol
PostPosted: Wed Sep 01, 2010 8:35 pm
the best place is in the upper hose of the radiator, looks like you have to sort out a new package of radiator & intercooler hoses
you definetely should consider to turn the compressor housing down, so you can save death volumina & space
PostPosted: Wed Sep 01, 2010 8:54 pm
HI Sunny :) i dont think there is room to clock the turbo compressor as the 52mm rad takes up a lot of room,
PostPosted: Wed Sep 01, 2010 8:58 pm
...somewhere between the dump valve and the fuse box ?
PostPosted: Wed Sep 01, 2010 9:04 pm
ok thanks ill have a look at the weekend to see what room i have :)
